Home Forum Ask A Member Carb crud
Viewing 10 posts - 1 through 10 (of 21 total)
  • #5437
    amuller
      I opened a carb this evening and the bowl was loaded with maybe a heaping tablespoon of what looked very much like damp brown sugar. I’ve never seen anything like this in a carb before. Is it unusual? Also noticed that the bowl was stuck on tight, such that it required definite effort to get it off. Gasket was a plastiky material.
      #45299
      david-bartlett
        Been there and seen that! I don’t know what the cause is, but I have had good luck getting it all out. Almost like sand.
        #45303
        fisherman6
          Yup, I have seen it too. That’s quite a lot of it but I have seen it in a number of carbs I have worked on. I’m not quite sure what it is either. Looks like it may be some congealed varnish bits or something. I have been soaking all my carbs in Berrymans Chem Dip for 30-40 minutes now then flush them out with spray carb cleaner and compressed air. I have had good success with this so far.
          -Ben
          OldJohnnyRude on YouTube
          #45563
          amuller
            This morning I tried dissolving the stuff in E-85 (ethanol), E-10 (normal gas) and acetone. So far It doesn’t entirely dissolve in any of those. Given that the filter had been bypassed I’m wondering it some of it is just dirt (sand). The liquids turn yellow so clearly some is going into solution.
            On soaking in carb cleaner, somewhere recently I read a service bulletin (or something) saying not to do that as it would remove an anti-porosity coating from the carb castings. The advice basically was just carb cleaner spray and compressed air.
            What say you experts on this?
            am
            #45565
              BRP says not to soak their late model carburetors because it removes the porosity sealant. Not an issue if you are working on our old stuff.
              #45596
                http://s1088.photobucket.com/user/1cros … t=2&page=1
                see crud inside a CD… I used a small nylon brush and pine sol to clean everything out.
                #45604
                amuller
                  Wow, that carb was nasty! I didn’t think of using PineSol. Will try that next time.
                  I notice you used vinyl fuel lines. Have you found them to hold up well?
                  That motor looks great!
                  am
                  #45607
                    I used plastic tube sold as fuel line for motorbikes…so far so good
                    but I think the blue or yellow tubing could be a better choice
                    just soak the carb in 50/50 solution for an hour then scrub the crud out
                    clean all passages with carb cleaner and blow dry with high pressure air
                    #45670
                    PugetSoundBoater
                      Frank -the later carbs..would that include my 1989 9.9? Of course i won’t soak the plastic top or bowl . I planned on using the OMC Engine Tuner for a good soak on the metal parts and rinse well with spray gumout,blow dry with air .A photo in the 89 manual shows them spraying Gumout.
                      Monkey see, monkey do.
                      Robbie Robertson
                      #45715
                        I plead ignorance on anything that new. The only ’89 manual I have is for larger motors, and it says not to soak them. I will say that it makes sense that they may impregnate the castings with a porosity sealant. We did that with certain parts when I worked at Hynautic (hydraulic steering mfr). On the other hand, unless there actually is a porosity situation with your particular one, the sealant does nothing. Feeling lucky?
