Home › Forum › Ask A Member › Carburetor Kit issue
- This topic has 8 replies, 8 voices, and was last updated 7 years, 5 months ago by
jerry-ahrens.
September 22, 2018 at 7:32 pm #11305
In the last 2 months I have ordered the same carburetor kit (by P/N) from 2 different Ebay suppliers and both kits have exactly the same issue.
The P/N of the kits is 439071 (18-7043). The motors in question are: 1954 Fleetwin and 1956 Fleetwin. Both kits are Chinese manufactured. On the pkg is the number "P870" or "R107".The issue is that the needle seat will not proerly thread into the carb body. They will partially thread but then severly bind indication a thread mismatch. I have tried the two different seats with a half dozen carb bodies and the result is identical. Has to be a thread problem with the seats.
Anyone else having a similar issue?
DrifterSeptember 22, 2018 at 8:29 pm #83374yes. twice with kits for MD 1A, 2A, tillotson carb kits. had to use the old part . tried
to use tap and die set to re-thread, but couldn’t use the stuff I had.September 22, 2018 at 8:42 pm #83375yah i had that issue with a 1975 2hp evinrude. I suppose you get what you pay for as the saying goes. I used the old one with a new needle. It worked but yah wasn’t pleased that i spent money on new parts and had to use some of the old ones.
September 22, 2018 at 9:51 pm #83383Their part has metric threads? Ben Franklin tried to have us go metric in 1784. The Government tried again in the ’70s. People were downright hostile to liters of Gasoline and Kilometers per hour in speed limits . . . 🙄
September 22, 2018 at 10:38 pm #83386I sure wish you guys were metric. It would make things so much easier. We are officially metric in Canada, but most of us can work in both systems to some extent
Wayne
September 22, 2018 at 10:49 pm #83387Well, I measured the carburetor as 5/16 – NF24. So, I ran the faulty seat through the die then very closely (very high magnification) examined the threads and they were slightly scuffed, but, very slightly. The part seemed to fit fine following the trip through the die.
Doesn’t seem right to me that the sellers advertise the part as a fit for the specific carburetor and the part does not fit.
Drifter
September 23, 2018 at 12:55 am #83390Buy OEM carb kits only. Problem solved. You get a float that way as well.
September 23, 2018 at 2:34 am #83394Thanks Chris, i buy the OEM just to get the float.
2Fast4Me
September 23, 2018 at 10:42 am #83399Yeah, anything other than OEM is junk… You can buy NOS OMC carb kits on EBay sometimes real cheap. I just bought some 439071 kits for $13.00
