Home › Forum › Ask A Member › CC Comander….compression and flywheel puller
- This topic has 9 replies, 5 voices, and was last updated 7 years, 10 months ago by
bsplit.
April 8, 2018 at 4:24 pm #9583
I have three CC Commanders, and would like to get one running. One of the three is just a parts motor, and I can make a good motor out of one of the other two.
The compression on one is 140 and 135. The other one is 119 and 120. I’m wondering what normal compression is on a Commander.
Also, the slots on my flywheel puller aren’t long enough to reach the holes on the flywheel….they are way out by the edge of the flywheel.
I plan on going to Mark Suter’s meet next Saturday.
Any help will be appreciated.
Thanks,
JimApril 8, 2018 at 4:42 pm #73619Jim, I just pulled the rewind off a Commander (that I just picked up yesterday..) and that bolt circle IS bigger than a normal flywheel/harmonic balancer puller. I’m 99.9% sure I have access to one that’ll work….and I’ll bring it to Mark’s next Saturday.
Jim
April 8, 2018 at 4:52 pm #73620Sounds good….Thanks, Jim
April 8, 2018 at 5:23 pm #73624Y’all got one of THE most knowledgeable Chris-Craft people over there in Michigan – and you ain’t calling him???
Leroy Holland in Algonac. Tell him the Prime Minister sent ya
Best,
April 9, 2018 at 2:51 am #73652Pick him up on your way to Suter’s
April 9, 2018 at 8:44 am #73660A good healthy Commander will have right at 140 psi WITH the high compression cylinder head. The early Commanders did not have the upgraded head, and will be a little lower than 140.. Chris Craft came out with the high compression head upgrade, so you could soup up your motor. Be careful with your ignition points, if you break them, their hard to come by. Wait till you run that motor….you’l love it! Man they are screamers.
Ask Lee Holland about the casting #s on the cylinder heads, as I can’t remember the #’s off hand with regards to identifying them. I would have to drop the cowl jackets on mine and look to see. let me know if you need more info.April 9, 2018 at 1:14 pm #73667quote Bsplit:Pick him up on your way to Suter’sNot going to Suter’s, I’m headed to a goalie clinic
PM T2
April 10, 2018 at 10:34 pm #73768Thanks, Jerry……and Chris…..don’t get hurt
April 11, 2018 at 12:29 am #73777Anonymous
I made a puller and i think if I remember correctly the holes in the flywheel for the puller bolts are an odd size threads, that I had to also order a special die and make my own puller bolts.
April 11, 2018 at 3:04 pm #73813XR55….I just checked the holes used for the puller, and it is a common size fine thread. I used some fine threaded puller bolts used for another motor, and they do fit. A couple years ago, when trying to find bolts for the flywheel of a Johnson 9.8 hp KD15, I couldn’t find any. A Florida AOMCI member suggested that I drill, and retap the holes on the KD15 so I could use standard size bolts.
Thanks,
Jim -
