Home › Forum › Ask A Member › CD11 hood rear bumpers
- This topic has 20 replies, 9 voices, and was last updated 2 years, 3 months ago by
JACQUES.
February 4, 2022 at 12:07 pm #253937
I’ve used thick fuel line to replace the front bullet bumpers on Johnsons but I really like this idea of using tire valves for the rosettes!
That’s the best idea I’ve seen in ages and can’t wait to try it out. Thanks for the tip Steve!
Princess Auto also carries them in four packs.
February 4, 2022 at 4:43 pm #253976Canadian tire 2 for $5.50 Amazon… totally cheap for a 20 pack
for a 50 pack…don’t cut up you fuel lines… 🙂
STEELMAN 96437 TR415 Snap-in Rubber Valve Stem, Pack of 50, Valve Stems & Caps – Amazon Canada
This reply was modified 4 years, 1 month ago by
JACQUES.
February 4, 2022 at 6:48 pm #253986Great solution with the tire valve stems and at the right price. I’ll try these on my next project.
"Every time you remove a broken or seized bolt an angel gets his wings."February 5, 2022 at 9:55 am #254026I got my rubber plugs at the local Aubuchon hardware store. They are in the boxes of loose fasteners, knobs, etc.
February 5, 2022 at 10:18 am #254027I had not checked that section of my big hardware store….
Ho well….. I went and picked up some TR415 valves….. ONWARD !!!! I’ll post my pics soon
Steve D gets the “McGiver of the month” award 🙂
February 5, 2022 at 3:01 pm #254065haha thanks crosbyman, I wish I could take credit for that one. I actually got it from a fellow local outboard guy years ago. A few things I did, if I remember correctly….after taking out the core, I put it in the vise “bottoms up” with the threads clamped in the vise, it doesn’t matter if the threads get “squished”. I used a 1/4″ bit, variable speed is better cuz if you go too fast it may have a tendency to grab and twist the whole thing. Go as fast as you can without binding but start on the slow side. After the brass innards are gone, then cut to length and I think I might have used either a Dremel cut-off wheel or hacksaw. At that point with just rubber remaining even a diagonal cutter probably works.
Steve D.
February 5, 2022 at 4:09 pm #254069thanks… I have rear bumper post missing and need to reinstall one … best I could figure out the posts are 12nc24 thread….if not it will be soon 🙂
I’ll glue (JB) the new post in and set the modified tr415 valve over it. 🙂 should be fine
thanks again for a good tip.
February 6, 2022 at 1:28 pm #254099update…
missing rear rosette replaced with shorten TR415 valve …new mounting post installed …. about 5/32 12NC24
TR415 valve was cut to same length as the remaining rosette… then I pushed out the brass sleeve inside & latex glued over the new post looks great fits perfect 🙂
SteveD … cutting the valve to size (hacksaw) first prevents the need to drill out the valve section ! Only a short piece of brass remains in the valve body and can be pushed out 🙂
February 6, 2022 at 1:40 pm #254102Glad it worked out for you. I could have saved myself some work if I had thought about doing what you did. Makes it even easier now to use these. Thanks for the tip!
November 29, 2023 at 4:15 pm #282895Go to a tire shop & get used tire stems for free.
