Home › Forum › Ask A Member › CD12 strange cooling issue
- This topic has 43 replies, 12 voices, and was last updated 8 months, 2 weeks ago by
Mumbles.
June 27, 2025 at 9:59 am #297604
Hi All,
Just completed the restauration of my new to me CD-12. I’ve completely overhauled the gearcase, ignition, carb and replaced the impeller, prop shaft seal, drive shaft seal, and the shift rod O-ring. It fired almost immediately, but it’s pumping just a tiny amount of water. It starts with a reasonable amount (but about half of what I’d expect) and then reduces to just a trickle after 5 or 10 seconds.
To isolate the problem I’ve removed the power head and put a drill on the drive shaft. Water then shoots out a couple of inches above the top of the draft shaft.
So I figured the problem must be in the power head. I removed the side/exhaust cover and surely enough one of the bolts broke. Apart from that everything looked as clean as a whistle. Just to be sure I blew some pressurized air trough all the openings to check for blockage, all seemed good. So I closed it up again and ran it in a barrel. Problem not solved.
Then I removed the cylinderhead, just to make sure all the passages were clean. They were.
Any ideas as to what else could be causing this problem or where to look?June 27, 2025 at 11:19 am #297605did you install the proper base gasket# under the PH ??
see pattern differences …
June 27, 2025 at 11:34 am #297608Thank you Crosbyman.
I’ve reused the existing base gasket but ordered a new one at vintage outboard.
The current one needs replacement but seems to be original and correct.
I’ll pull and inspect the pump housing later today and let you know how that worked outJune 27, 2025 at 11:43 am #297609check pump impeller key !
btw if you need the Cd12 parts listing I can send via email …file is 3meg +
send me PM with Email
June 27, 2025 at 12:18 pm #297610I’ll also check the key but I’m fairly confident that it is OK. Thanks also for the offer for the parts manual but I’ve already downloaded it from the forum. Probably posted by you 😁
June 27, 2025 at 12:18 pm #297611Back to the shop….
June 27, 2025 at 12:34 pm #297612Crosbyman,
In order to eliminate the base gasket, would it do to remove it temporarily and check the waterflow?
Or will that actually prevent the water from flowing down the proper channels?June 27, 2025 at 12:58 pm #297613I don’t think it’s the water pump or lower unit
June 27, 2025 at 1:14 pm #297615I would not operate without the base gasket as long as it is the correct one it should not be the problem you seek.
water could seep out and into a place it will cause worse problems!
if water does not come in properly……….. it is restricted going out and there is no thermostat anyway.
remove the rear exhaust cover 303585 to inspect the outflow of water or try a backwash to clear water passages.
did you pull cyl head and inspect jackets ??
June 27, 2025 at 1:30 pm #297616Well, what I thought was an original base gasket seems to be a custom made one. Which would make sense because these are impossible to get over here. Don’t know how I’ve missed that, usually these gaskets are black, not creme.
One of the holes was blocked, the one I’m pointing at with my finger. I’ve opened it up thinking I had found it. But it made no difference at all. Yes I’m running the engine without the rear exhaust cover so I have a visual on the water flow.
I’ve also checked all the water passages in the cylinder head. No debris or pieces of impeller on there.
My main suspect at this moment still is the base gasket, although water can flow freely from what I can see. -
