Home › Forum › Ask A Member › CD12 strange cooling issue
- This topic has 43 replies, 12 voices, and was last updated 8 months, 2 weeks ago by
Mumbles.
June 27, 2025 at 2:03 pm #297618
Remarkably that same hole is also not there in the gasket listed on vintage outboard
June 27, 2025 at 3:57 pm #297624not sure what you have there…an open passage may cause water pressure loss or a blocked passage way could do the same !
install the correct gasket
if the PH is off.. .why not backflush it or front flush it to see how much water does get restricted ..or not .
give it a shot of 100psi blast … or flip the ph upside down and fill the water inlet with warm 10-20% vinegar overnight. It may dissolve some crudded passages
June 27, 2025 at 4:30 pm #297625Yes I’ve ordered a new gasket, but it will take a few weeks to arrive. In the mean time I would like to eliminate other possibilities.
Assuming you mean a blast of air, I’ve done that already. I’ve found nothing that was obviously wrong.
Regarding back/front flush, that would be using water, right? That would give a clear idea if anything is blocked or not since water behaves differently than a blast of air. A blast of air would get past an obstruction easier than water.
What is the difference between a back or a front flush, just the direction of the flow of the water? I’ve never flushed the powerhead before.
June 27, 2025 at 5:13 pm #297626
Try the drill on the drive shaft again but this time block the flow with you finger looking for water squirting out anywhere. Then slip your finger off and watch how well the flow recovers.
June 27, 2025 at 5:34 pm #297627the ph has an incoming water passage at the upper end of the water tube. The water flow may or may not be distributed by the fancy gasket when installed and doing it’s thing but see if you can establish the cooling routes into sections of the PH and pump water in and look at the output water ports. One certainly dumps water in the exhaust cavity.
Once you have established the flow routes and pumped in water you will see if the ” inflow” looks restricted from exiting the PH… indicating internal blockage blockage.
water should flow out where it normally dumps the
June 28, 2025 at 2:10 am #297638
Thanks Tubs.
When I put my finger on the hole, pressure builds up immediately and the water forces itself past my finger. It hit the ceiling in my workshop. So I’d say that has both plenty of volume and pressure. It seems to confirm the problem is higher up.June 28, 2025 at 2:12 am #297639Once you have established the flow routes and pumped in water you will see if the ” inflow” looks restricted from exiting the PH… indicating internal blockage blockage.
I will give this a try, hopefully today.
June 28, 2025 at 7:23 am #297640
My guess would be you have the remains of a failed impeller that are moving around to block the flow of water as it begins to pass through the power head.
June 28, 2025 at 8:00 am #297641Could the grommet at the top be collapsed and be restricting the flow? Or tube not entering properly, that will also give some water but not proper amount…
Richard
classicomctools@gmail.comJune 28, 2025 at 8:49 am #297642top grommet looks fine (see water sprouting & drill test ) likely an obstruction has suggested. I would try to fish a very small diameter SS strand wire inside all access points ( IN water port, Water exit port, Jacket incoming source and exit holes etc..etc..
