Home Forum Ask A Member Century shift lever
  • #2292
    msky2
      I can not get shift lever out of cap that is on rod for shifting trans I can not shift to forward or reverse cap seems to slip on rod is the shift lever used as a set screw on the cap in order to rotate rod to shift trans
      #22185
      JOHN D.
        What brand outboard do you have? If it’s a British Seagull it only has forward and a neutral position. Interesting way they accomplish this as the prop is pushed away from the gearbox to disengage the prop.
        #22187
        msky2
          It’s a inboard. With shift lever at the wheel
          #22200
          JOHN D.
            Well that explains it.
            #22211
            wiscoboater
              What type or brand of motor and control is it? Mercruiser, Volvo, OMC? The boat brand does not help due to Century using many different motors.
              #22224
                msky2
                You might try the "Old marine engine" web site.
                http://www.oldmarineengine.com/
                Good Luck with your boat.
                Steve A W
