Home Forum Ask A Member Champion Blue Ribbon 1J
  • #256057
    Ronald Smith
      In the process of tearing down my 1J organ donor.
      Tank, carb, flywheel, and magneto/coil plate depopulated.
      The stator magnets cannot be removed due to a keyway. My question is if this is a Woodruff key that is removable? If so, I will try persuading it and bit.
      Ron
      #256062
      JOSEPH BRINCAT
        Did you download the owner’s manual the mumbles was kind enough to post on your former thread? the parts diagram shows the mag rotor key , part 1J505, to be a woodruff key.
        #256063
        Ronald Smith
          I do have a 4 or 5 page 1J 1K manual PDF.
          I looked for it, but could find it. I will look again using that PN.
          I will also look for what mumbles posted.
          #256064
          Ronald Smith
            Joe B,
            Found it in my little manual. PB blaster, tap tap tap. Needle nose vice grips. Pull pull pull. Out she came. Found a second one below that.
            As you might be able to tell, I am new to this. Next the power head. It looks like I has a JB Weld patch on top. Since it is likely trash, I will tear it down completely. First time doing that also.
            Thanks for the nudge.
            #256072
            JOSEPH BRINCAT
              Good job Ronald, you will see that this web site and club is all about learning.  Outboards are pretty inexpensive and simple… good for learning and “playing”
              #256100
              Ronald Smith
                Yep. Agreed all the way around. Thanks to all again. I’m sure I’ll have more to ask later.
