Home Forum Ask A Member champion blue ribbon coils
  • #11173
    ronboonville
      I want to buy this motor. Can I use omc coils?
      #82669
      ronboonville
        Also where can I get an impeller? Were they made by Scott atwater?
        #82674
        cajuncook1
          Do you have a year, hp, and model number. Post a picture of the motor and a pic of the rope sheave or any location on the motor that has a serial or model number.
          #82687
            Lots of Champion models. Need to know which one. Some use Phelon or Scintilla coils (like Mercury. Some have metal centrifugal impellers, some have rubber.
            #82709
            lindy46
              I have a Champion Majestic and used standard OMC coils, but I had to remove them from the laminations and install them on the Majestic coil laminations.
              #82722
              outbdnut2
                The model number is often stamped into the side of the transom clamp assembly and may be painted over but still legible. It will likely be a number and a letter, like 1J, 1K, 4K, etc, but some have more characters, like the Hydrodrive units where model may be a format like 4LHD. Like Frank said, some never need an impeller if it is aluminum.
