Home Forum Ask A Member Champion Hrdro-Drive
  • #2679
    mercuryman
      How do you control the HD should the HD lever move the back with the motor off ? I just got a 2LHD running but it won’t go in HD.
      #24974
      JOHN D.
        What kind of lube is in the gear box? Should be something like 90 wt gear oil.
        #24978
        mercuryman
          Its full looks like 90 w
          #24983
          JOHN D.
            Check into the fiberglassics library. There is service information on the hydrodrive there. I just bought a Champion 4.2hp hydrodrive and it seems to have the same problem. Maybe running on a boat under load may help. Good luck, hope the impeller on yours is good as i’m trying to find one i can make work on this one.
