Home › Forum › Ask A Member › Champion Rebuild Questions
- This topic has 4 replies, 3 voices, and was last updated 5 years ago by
Buccaneer.
March 7, 2021 at 9:21 am #233175
I’m cleaning up the powerhead on my Champion Lite Twin and had a few questions:
1. The head gaskets are a metal reinforced fiber material (metal core with fiber each side, see pic). Do I have to go back with the same type of material or can I just a good quality Fel-Pro fiber gasket of the same equivalent thickness?
2. Is a gasket sealer required for the head gasket or the crankcase-cylinder gasket? Existing gaskets were apparently installed dry.
3. I find the pistons do not have a locating pin for the 2 piston rings. I assume I should position the rings with the end gaps 180 degrees apart and not in line with the cylinder ports?
"Every time you remove a broken or seized bolt an angel gets his wings."March 7, 2021 at 9:54 am #233182Even if you could find the correct metal reinforced gasket material, it would
be hard to work with. I wonder how a milling machine would work?
Randy in Tampa had some professional gasket made up for the PO-15’s
I believe. Not sure of the name of the outfit.
If you go with “make your own”, then at least look for the proper thickness
and something with a high temp rating.
I’ve made some for small engines out of fiber gasket material and gooped them
up good with the high temp copper gasket sealant. I never ran them long
enough to see how they will hold up.Prepare to be boarded!
March 7, 2021 at 9:59 am #233184I know that some folks have sent old gaskets off to Cometic to have them make up new ones. Fel-pro has a metal reinforced material of the same thickness, but as you noted, customer reviews said it was hard to work with. Cometic does have a high density fiber gasket that is allegedly fuel and oil resistant and good for temps up to 650 degrees. Thought I might try that.
"Every time you remove a broken or seized bolt an angel gets his wings."March 7, 2021 at 10:49 am #233187Those 4-bolt Champion/Scott heads were sort of notorious for blowing the gaskets. That’s probably why they later went to 6-bolt heads.
March 7, 2021 at 12:47 pm #233194I know that some folks have sent old gaskets off to Cometic to have them make up new ones. Fel-pro has a metal reinforced material of the same thickness, but as you noted, customer reviews said it was hard to work with. Cometic does have a high density fiber gasket that is allegedly fuel and oil resistant and good for temps up to 650 degrees. Thought I might try that.
That’s why I was wondering if anyone tried making one on a milling machine……
Hard to work with some of that material. Perhaps a small cutter in a
Dremel would help out?Prepare to be boarded!
