Home Forum Ask A Member Cheap fix on expensive plastic ETEC cowl
Viewing 1 post (of 1 total)
  • #10254
      fyi….I recently repaired bolt mounts broken off my ETEC lower cowl halves with great a success using this stuff and then covered up with Permatex plastic welder (2 part mixt seringue) imbedded with a layer of fiberglass cloth
      https://notaglue.com/
      3 seconds under UV light and the glue sets hard… just like tooth repairs at the dentist …without the dentist $$$$$ πŸ˜†
      then you just add a layer over the cracked plastic followed with the UV lamps supplied followed with the Permatex layered FB cloth
      saved me buying 2 lower cowl halves totaling around $1400 cdn incl taxes πŸ˜€ πŸ˜€ πŸ˜€ πŸ˜€
