Home Forum Ask A Member cheap sportwin ?
  • #8492
    kees
      International Member
      cheap !
      but a Frankenstein 🙁
      I see a wrong muffler and a wrong lower unit
      are there more issues ?
      https://www.ebay.com/itm/Vintage-1926-E … 2692339810
      #66370
      Tom
        That’s not a Sportwin, that’s an RS Fastwin, late ’27. The early versions used the Model N style lower unit, the later ones used the TS style with the centrifugal pumps. That motor has an intake manifold. The muffler is correct for an RS.
        I emailed the owner with the correct information the last time he posted it, but he didn’t update anything.
        WELL worth the money if you can pick it up.
        Tom
        #66371
        PM T2
          Tom beat me to it…. but yeah, Looks more like a Model "R" than it does an "N", to me at least.
          Lower unit, exhaust, cylinders, and intake/carb assembly all look like 1927 Model "R" four HP parts to me.
          Best,
          PM T2
          #66372
          PM T2
            same seller also has a Lockwood 82AS for sale, badly painted Ace but has brass lower unit
            https://www.ebay.com/itm/1928-Lockwood-Ace-outboard-engine-82A-/282680053275?hash=item41d10b4e1b:g:AR8AAOSwimhZ1Dgq
            worse looking motor, lots more money than the RS
            PM T2
            #66384
            kees
              okee, I see
              then it has a wrong tank or at least a wrong ID plate
              local pick up only, well good luck, not for me 😮
