Home › Forum › Ask A Member › Cheating with synthetics?
- This topic has 25 replies, 16 voices, and was last updated 9 years, 9 months ago by
shoestringmariner.
June 14, 2016 at 4:27 pm #38271
Thanks everyone!
I got a PM but I can’t find a reply button….but thank you for your input!June 14, 2016 at 4:35 pm #38272Anonymous
I thought being a member of this club was about preserving old motors.
I use full synthetic Penzoil at factory specs. My middle daughter is a bit of a
treehugger [we call her this with love]. She saw the oil slick one time and asked
if that was bad for the water or not. So we switched to full synthetic.I bought Penzoil synthetic blend once and found it to be the foulest smelling
oil I’ve ever used!So I keep em slick and smokey like a 2 stroke was designed to be!
Steve A W
June 14, 2016 at 9:08 pm #38276Why do you want to lean out the gas/oil mix? If you have spark plugs fouling too often, I’d use a heat range hotter plug and it will stay cleaner. If it’s for smoke, most motors only smoke much when they are first started anyway. Even my 16 HP Johnson that runs at 8 to 1 does not smoke hardly at all once it’s once it’s warmed up and haulin’. Note I only use the generic brands of TCW3 rated oil – like Walmart’s house brand and have no problems. Years ago Dad and I ran straight 30 non-detergent at 20 to 1 in a 1960 40 Johnson and 40 to 1 in a 1965 60 Johnson – running well over 200 gallons of gas a summer in each motor with no oil-related problems. That 60, we ran that way for 10 years (hmmm – that’s over 2000 gallons of gas) and it was runnin’ great when he traded it. My advice – run rated ratio or a bit more oil. Note the 20 to 1 and 40 to 1 were convenience things – a quart or a pint into a 5 gallon can of gas – then dumping that into the 6 gallon motor tank as needed. Note less oil will not give you more speed. Also interesting that the 16 HP that Champion outboard (called a Hot Rod) sold as a class B hydroplane racing motor in the 1950s was rated to use a 4 to 1 mix!
DaveJune 15, 2016 at 2:32 am #38302Guys, i don’t want to ruin this motor. I was hoping to achieve a few things;
1) reduce the smoke
2) reduce the oils slick, if only slightly
3) make the motor run betterI have heard accolades about Amsoil, lucas etc, and that their superior qualities reduce the need for such a heavy mix. So if I can do these things (WITHOUT PREMATURE WEAR), then why wouldn’t I?
I am also wondering about eco oils or bio oils and if they work with old motors, but I will save that for another thread 🙂
June 15, 2016 at 1:04 pm #38319A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
This reply was modified 7 years, 4 months ago by
Tubs.
This reply was modified 5 years, 1 month ago by
Tubs.
June 15, 2016 at 1:48 pm #38324Tubs,
While running a drier gas /oil mix goes against my practices and recommendations, I’m not closed-minded to the idea of reducing the amount of oil used. I am certainly concerned for the environment and want to keep the ability to run our motors in as many places as possible for as long as possible. I have strongly considered switching to a biodegradable fully synthetic TCW3 oil once my current supply is used up. I have about 2.5 gallons of synthetic blend left. While this would be considerably more costly monetarily, maybe I would be doing my part to reduce the overall cost and impact by doing this.I may need a bit more convincing / evidence that I am actually able to run less oil in the mix on the older babbitt and bronze bushing motors though. It’s still difficult for me to imagine that a more modern 2-stroke engine gets enough oil at 50:1 mix. I also know that the materials and processes uswd in building the newer engines have improves a lot along with the oils. I believe that lubrication technology has improved greatly over the past 60 years give or take from when many of these engines were new. I’m just not totally comfortable with how much better and I don’t want to of promise longevity of the engine. While I’m not totally on board yet, don’t feel like I’m the opposition either. 😉
You are completely on point when you say the stuff that starts in CA will migrate East. It always does and it is indeed an early warning. I just need to know I’m not ruining my motors by trying to comply.
-BenOldJohnnyRude on YouTube
June 15, 2016 at 2:26 pm #38327A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
Tubs.
Tubs.
June 15, 2016 at 2:41 pm #38330Thanks for the PM Tubs!
June 16, 2016 at 9:29 am #38388Tubs how about showing us your objective results in a post here ❓
June 16, 2016 at 2:44 pm #38408 -
