Home Forum Ask A Member Choke solenoid (12v) for Evinrude 30 Hp 1956
  • #4085
    randy
      hello – I am refurbishing this 1956 Evonrude. 30 hp, and I want to convert it to 12v. I need the choke solenoid. Can anyone help me locate one?
      #35117
        Place a wanted ad in the classifieds here, someone will have one for you. t
        #35122
          have you considered just adding an external resistance to the 6v selenoid coil…this will drop the voltage down to 6 volts
          if you can measure the current draw of the coil while activated at 6 volts you could estimate the operating resistance under load.
          V/current= resistance
          adding an equal resistance value ( try one good for a couple of watts) in series with the control wire will drop the 12 V in half and you r coil should work fine…without burning up.
          #35133
          chinewalker
            Pretty sure I’ve got one (or three). Drop me a PM…
