Home › Forum › Ask A Member › Choke switch Evinrude V4 1972 85 hp
- This topic has 15 replies, 3 voices, and was last updated 8 years, 7 months ago by
amuller.
July 29, 2017 at 10:13 pm #7782
I’m finally closing in on getting controls working for this.
The choke setup seems a little odd–the solenoid has two windings, one controlled by a switch and fulling closing the flaps. The other controlled by a thermal switch and apparently giving partial closure during warmup. The wiring diagrams show a separate choke switch but there is none in the control box and the key switch is not the push-to-choke type. Of course I can install a separate switch somewhere but what is the original setup? Also, is the switch supposed to be a momentary contact, and is the feed supposed to be from the start terminal or the "ignition" ("on") terminal of the key switch?
Probably an operator’s manual would clarify this stuff but I haven’t found one.
The control box I’m using is similar but not identical to this one: http://www.marineengine.com/parts/johns … &sid=38966
Thanks.
July 30, 2017 at 12:03 am #62381July 30, 2017 at 12:09 am #62382The service bulletin says to remove the Purple/yellow choke solenoid wire from the terminal strip and connect it to the screw with the two purple/white wires. Then when you flip the choke toggle, BOTH choke solenoid windings are activated for full choke. Warm-up choke will no longer work. Of course if you like the warm-up feature, leave it as is.
July 30, 2017 at 12:13 am #62383You can install a push-to-choke key switch in the box.
July 30, 2017 at 12:13 am #62384quote amuller:I’m finally closing in on getting controls working for this.The choke setup seems a little odd–the solenoid has two windings, one controlled by a switch and fulling closing the flaps. The other controlled by a thermal switch and apparently giving partial closure during warmup. The wiring diagrams show a separate choke switch but there is none in the control box and the key switch is not the push-to-choke type. Of course I can install a separate switch somewhere but what is the original setup? Also, is the switch supposed to be a momentary contact, and is the feed supposed to be from the start terminal or the “ignition” (“on”) terminal of the key switch?
Thanks.
OK, well that style control box should have a push to choke key switch….Perhaps someone changed out the switch improperly. I would pull the box apart and look for the purple white lead, which is the choke lead. Perhaps someone just left it laying inside the box connected to nothing…
July 30, 2017 at 12:19 am #62385Um, the control that you linked to is not for the Hydro-Electric shift and won’t work on a Hydro-Elect.
July 30, 2017 at 12:35 am #62386Good point Frank!
Why don’t you post some pictures of just what you have in terms of control box and wiring….July 30, 2017 at 12:55 am #62388quote FrankR:Thanks, Frank. This is a clearer diagram than the one I’ve been working with.
Question: I’d thought OMC used "selectric" only for the spring-clutch gearboxes, not the "hydro-electric" ones. Guess not….
July 30, 2017 at 12:57 am #62389quote FrankR:The service bulletin says to remove the Purple/yellow choke solenoid wire from the terminal strip and connect it to the screw with the two purple/white wires. Then when you flip the choke toggle, BOTH choke solenoid windings are activated for full choke. Warm-up choke will no longer work. Of course if you like the warm-up feature, leave it as is.Thanks. I think I will leave it as is and see how it works. Did OMC identify a defect that makes it desirable to simplify the choke wiring?
July 30, 2017 at 12:59 am #62390quote fleetwin:quote amuller:I’m finally closing in on getting controls working for this.The choke setup seems a little odd–the solenoid has two windings, one controlled by a switch and fulling closing the flaps. The other controlled by a thermal switch and apparently giving partial closure during warmup. The wiring diagrams show a separate choke switch but there is none in the control box and the key switch is not the push-to-choke type. Of course I can install a separate switch somewhere but what is the original setup? Also, is the switch supposed to be a momentary contact, and is the feed supposed to be from the start terminal or the “ignition” (“on”) terminal of the key switch?
Thanks.
Seems like it. Yes, the purple-white lead is in there, and not long enough to go anywhere else.
