Home Forum Ask A Member Choke switch Evinrude V4 1972 85 hp
  • #62391
    amuller
      quote FrankR:
      Um, the control that you linked to is not for the Hydro-Electric shift and won’t work on a Hydro-Elect.
      Quite so. But I have ginned up an improvised shift control and rung out all the leads. It works, but I haven’t been able to figure out a way to interlock it to prevent shifting at high speeds. Probably as soon as I have it all together a proper box will turn up.
      #62394
        Some people reported hard restarting after a short run and shutdown due to the thermal choke doing its thing on a motor that wasn’t warmed up but didn’t need choking to restart. Stuff like that.
        #62395
        amuller
          A couple of my Big Twins have pretty complicated choke setups.
          I wonder: With cars having been injected for quite a while, and mowers more likely to have primers than chokes, young people might not know what to do with a choke.
          #62412
          amuller
            One more wiring question:
            The gray tach lead from the "amplifier" lands on Terminal #7.
            The gray tach lead from the control box harness lands on Terminal #3-4 (jumpered) along with a bunch of other stuff mostly related to the alternator.
            So where does one hook up a tachometer sense lead? (I realize tachs vary….).
            And thanks again, Frank, for the wiring diagram.
            #62413
              The motor was originally wired for a special CD tachometer, rare as chicken fangs now. Today,s tachs are driven by the alternator and are connected to jumpered 3 & 4.
              #62777
              amuller
                quote FrankR:
                You can install a push-to-choke key switch in the box.
                I did. It was slightly larger and getting everything stuffed into the box with no pinches was a bit of a pain, but a neater solution than another switch.
