Picked up a Chrysler 5 HP #54HA but cant seem to nail down the Impeller Number for it.
Thought that would be easy.
Also the Model Numbers don’t seem to be consistent with the motor. Mine is a twin Cyl. and charts show it as a single.
I’m a little confused I guess. Chrysler has always been a hard one.
Carb number would be good too but I understand this may be an odd British carb and not very re buildable
I have the same motor. It’s a 1976. Impeller is part 47-F429065-2 and the carb is F 10049. The carb is super simple, give it a very good cleaning and should be fine. It’s an Amal carb. The only issue I had with the motor was the water tube was blocked under the power head. These are great running little motors and pretty peppy for a 5hp. The Fairbanks Morse recoil stinks but I deal with it. Best of luck. Dave
