Home › Forum › Ask A Member › Chrysler 8 hp Model 82 HG – spark plugs
Hello all. Working on the neighbors 1976 8 HP Chrysler Model 82HG. What spark plugs are recommended?
Thanks,
Believe this motor called for Champion L82C.
1937 Champion D2C Deluxe Lite Twin 1954 Johnson CD-11 1955 Johnson QD-16 1957 Evinrude Fastwin 18 1957 Evinrude 3022 1958 Johnson QD-19 1958 Johnson FD-12 1959 Johnson QD-20 1982 Evinrude 25hp
“Every 20 minute job is only a broken bolt away from a 3-day project.” "Every time you remove a broken or seized bolt an angel gets his wings."
Correction – should be L86C or QL86C.
Thanks Bob, good catch! I hadn’t gone out to buy em’ yet. I guess that the "86" vs the "82" is just a little hotter heat range.
OK
