Home › Forum › Ask A Member › Cleaning a 50’s OMC tank
- This topic has 9 replies, 8 voices, and was last updated 7 years, 11 months ago by
jerry-ahrens.
March 17, 2018 at 7:05 pm #9431
Just picked up a 58 Johnson tank. Inside is some surface rust. Was going to use the ammonia and nuts route. Question, is it ok to leave the solution in for a day or so with the aluminum pickup and foot? Don’t really want to take it out and break the top gasket seal. Any other cleaning solutions that might work better for this mixed metal environment?
March 17, 2018 at 7:19 pm #72605Take unit apart and do it right the first time
March 17, 2018 at 8:42 pm #72608I would agree take it apart and do it right probably needs a new gasket any way might as well get a kit and rebuild the tank that way you know it will not leak and lose pressure.
Doug
turned off?March 17, 2018 at 10:17 pm #72611I used a battery charger already and it worked so good. I don’t remember how I did it though .Maybe some one can post how to do it.
March 17, 2018 at 10:22 pm #72612I found this and there are other videos if you decide to try.
https://www.youtube.com/watch?v=5tgugq78V7YMarch 17, 2018 at 11:53 pm #72622For surface rust, electrolysis works well. Just don’t go crazy or you may take off the rest of the plating inside. Open the tank up and do it properly as others have said.
March 18, 2018 at 12:38 am #72627Bought your gasket/diaphragm kit yet? If so where did you get it. Looking for sources to pick some up.
KirkMarch 18, 2018 at 1:32 am #72629quote kirkp:Bought your gasket/diaphragm kit yet? If so where did you get it. Looking for sources to pick some up.
KirkI’ve gotten a couple from Jeff Laing (member) at http://www.laingsoutboards.com near Buffalo. Be sure to specify whether you need the kit with the metal priming button or the plastic priming button.
March 18, 2018 at 4:10 pm #72665I have used vintage outboard and Laing’s as well as marine engine.
Doug
turned off?March 18, 2018 at 5:31 pm #72667I use Super Clean and HOT water to remove the varnish and crud. A little rust here and there really wont hurt anything.
I’ve always made my own top gaskets out of cork, I buy it bulk at Oreilly’s. I like to use the thicker stuff, as it gives a better seal. Install the new cork clean and dry, with no sealer. You have room to snug up the screws later, down the road if you have any leaks.. When you get it apart, make sure the one way check ball inside the pick up tube is free.. shake it and listen for it to rattle around. -
