Home Forum Ask A Member Cleaning Aluminum Tanks
  • #3243
    drifter
      I am looking for the best way to clean the inside of aluminum fuel tanks.
      So far I’m thinking acetone with gravel or nuts and sloshing that around followed by a soak with ammonia.
      How long to soak it is the question. I don’t want to risk damage to the tank.
      Are there better ways to clean the inside of aluminum fuel tanks?
      Thanks,
      Drifter
      #29029
        If it’s just gas crud try E85 gas.
        I’ve done two steel tanks and it cleaned it up real good.
        Steve A W
        #29035
        dmbono
          I use Marine Clean, sold by POR-15, but Napa orders it for me. it works fast, cannot be left too long though.
          #29041
            Best and cheapest is just good old ammonia for dried fuel/oil crud.
            If rust, electrolysis works well.
            #29106
            johng
              If your tank is really bad inside Crystal Drano will clean it,Try 3 tablespoons & some water. With screws or nuts. Shake up and wait about 10 mins. Rinse out and check might have to repeat if bad. Then rinse with Baking Soda & water 2 times to neutralize Drano. Works very good if real dirty
              #29117
              elgin2
                Ammonia works great and it`s cheap.
                quote Chris_P:
                #29123
                JOSEPH BRINCAT
                  OOPS! … Drano is a strong alkali (sodium hydroxide), baking soda is also an alkali (sodium bicarbonate) but much milder. Baking soda will not neutralize another alkali. To neutralize an alkali you need an acid. After a good water rinse use something like vinegar, a mild acid.
                  #29129
                    Drano will also dissolve aluminum while giving off hydrogen gas at the same time. Drano bombs ring a bell? Machinists use it for cleaning end mills and other cutting bits which have become plugged with aluminum. Just sayin.
