Home Forum Ask A Member coil
  • #233899
    David C
      have a bad coil on my 1937 neptune 2hp ob12a.is there a coil that i can replace it with. thanks
      #234108
      JOHN D.
        Any coil that will fit without the flywheel hitting it will work. I have removed laminations and filed the center part down to make these 7/16″. An OMC coil will work quite well. I have a coil and plate with points if you want it.
        #234114
        JOSEPH BRINCAT
          Is that 2 hp Neptune an opposed twin? If so you will need rather special coil.
          #234123
          JOHN D.
            An OB12 is a single.
