Your replacement coil will most likely be coming from a doaner motor. These coils are pretty hardy, normally you find them in good condition. Are you sure that yours is bad? how do you know? no spark ? or did you just check it with a meter?
Check to see if yours is good. If not I think I have one. I can send it to you my usps if you need one at no cost. Paying it forward someone here helped me with a zephyr part at no charge!!
Joe
My coil is definitely not good. I would really appreciate your help and I sure don’t mind paying for the part or at least the shipping charges. It is so great of you to be willing to help me out.
I have a question i also have I think 1946-1948 zephyr 4404-00663 5.4hp outboard it has a manual wrap cord pull start I noticed 3 bolt holes on top is that so I can put a spring loaded pull starter?
