Home Forum Ask A Member Compression
Viewing 10 posts - 31 through 40 (of 62 total)
  • #245873
    Boonie
      Sorry about the float picture. That pic is opposite of the way it was installed
      #245907
      Boonie
        Maybe bottom crank seal. Could be why all the fuel comes out the exhaust?
        #246029
          I don’t think the bottom crank seal is the issue, even though the pieces might be messed up. Keep in mind that this engine has the overboard drain system, so excess fuel from a flooded crankcase will be directed toward that drain and down and out of the exhaust housing/gearcase. OK, so it seems like you have more or less ruled out the carburetor as the issue. So, it seems like the intake manifold is the next logical step. Again, you are sure that the fuel air hoses are connected properly? Keep in mind that if reversed, the fuel line will be directed to the intake manifold and will just fill the crankcase when primed.
          Is this motor new to you? If so, did it ever run correctly? You mentioned that it appeared that the intake manifold had been off before. If the engine is new to you, and has never run for you, then I would expect that something is messed up in there…Perhaps someone was trying to convert it to a single line/fuel pump unit. Perhaps the black rubber pressure valves are broken/messed up, maybe the intake gaskets are reversed….It only takes a few minutes to pull the intake apart, do you have new gaskets? Oftentimes the gaskets will come off clean, provided no one has used sealer on them….
          #246105
          Boonie
            Air and fuel hoses are correct and carb has also been checked. Motor is new to me and I know nothing of its history. Yes it looks like the intake screws have been off before.
            I’ll get it off this weekend and take a look. I’ll post some pictures when I do.
            #246109
            labrador-guy
              I gotta get my two cents in here! Did you blow all the ports and drilling out with compressed air when you had the carb apart? When you are cranking the engine with the choke butterfly closed you should see gas puddling around the butterfly. If not, I would take the carb apart and pull the low speed needle out and give that drilling a shot of compressed air and also blow the main jet that hangs in the float bowl.
              dale
              #246113
              Boonie
                Yup did all that. Soaked the carb in acetone, took the Welch plug out and blew everything out.
                #246124
                  How about this? I can see your air and fuel lines are okay on the engine but what about on the fuel tank? What if the tank end or the engine end of the double hose fuel line is reversed? Easy check: Pull the hose off the carb and pump the primer and see if good fuel comes out. I know, I know but it’s a very simple check before ripping into the intake….
                  #246136
                  Boonie
                    New fuel lines are clear. I can see the fuel flowing to the glass bowl . Lines are correct. Gas tank holds pressure. Carb needle and seat holding well. .
                    #246180
                    Boonie
                      I’m going to pull the intake manifold. Just because I don’t know what else to do. Never had one off, so not sure what I’m looking for. But I have to find the reason it’s flooding out the exhaust prop area. I’ll post some pics.
                      #246182
                      Boonie
                        Just before I pull the manifold I thought I would take a look at the ignition. Every time I check for spark I have a strong one on both cylinders. But after inspection, the coils are original and severely damaged but still creating a good spark. Could this be adding to the flooding problem?
