It took a long time to get it through my head that the very 1st thing one should do when getting a old outboard that you know nothing about ; before working on it was to check the compression.No matter what one does to it if the compression is low it will be hard to start ,won,t idle down or won,t start at all. This is typical with 2 cycle engines.Each model & brand outboard has compression stats from the factory where it will run as it,s suppose to.
My question  ,a TN -28    What is a good compression reading  with this particular outboard, will start ,idle & run well.?  I know a lot of  these particular outboard were damaged by mixing the wrong oil or wrong ratios back in there day making it hard now to find a good one these days.
Gene in Mn
