Home › Forum › Ask A Member › Compression required on 1940 Johnson HA, HS .to run
Hi All
Could someone please give me an idea of compression requirements and any other suggestions to get the above motors running.
Currently the best is 35lbs on both cylinders on both motors.
Thanks in advance Monte N Z
you need no less than 60 psi or greater
al
As Al says, 60 minimum, but 70 to 75 to be a great idler.
OK
