Home Forum Ask A Member condensors for Scintilla mags
  • This topic has 12 replies, 7 voices, and was last updated 5 years ago by Tom.
  • #233186
    rickinfarmington
      What is the current best source for kg-7 bendix magneto condensors?
      Rick in Maine
      #233236
      lloyd
        I don’t know if they are still available from Prefered Parts, but I still have some new ones in my shop. They are BE625- 10-79188-218578-55 (I have two) and 10-79188-219578-55 ( I have two of those also) I would like to keep 2 of the four for my restored and running KG7.
        #233279
        rickinfarmington
          thanks for the generous offer, but before I take two of these valuable parts, let me continue a while longer to see if any more sources are found. I have a number of KF and KG Mercs and I would like to just replace condensors in all of them if I can.
          Rick
          #233289
          seakaye12
              if you know the uf value of the parts to replace you could install a modern capacitor … probably for pennies
              see excellent articles by W.Mohat on capacitors in the last Outboarder edition or…. see condenser articles 1-2-3-4 at his link
              https://wrcoutboards.org/magazine-articles/
              .22uf is an all time favorite with some a bit bigger on older engines
              update: by the looks of seakaye12’s above post that condenser seems… not very old after all
              Joining AOMCI has priviledges ๐Ÿ™‚
              • This reply was modified 5 years ago by JACQUES.
              #233330
              Robert Neymeiyer
                They can be made by using the proper value capacitor and installing into the current housing.
                #233333
                rickinfarmington
                  Give me a price and address of where to send the money. A bird in the hand is worht two in the bush, like thay say.
                  Rick Matson
                  137 Hillside Drive
                  Farmington, Maine 04938
                  207-860-0962
                  #233356
                    these are .22uf 630V … not 850v but should work if you stuff them in an old capacitor can (weld one end on the casing via a 1/16 hole in the bottom (see w.Mohat technique)
                    seal it up with epoxy
                    https://www.amazon.ca/Cary-Yellow-Polyester-Capacitor-0-22uf/dp/B00LLGCL2C?pd_rd_w=gafl2&pf_rd_p=c1e82ed2-e887-470c-a24c-103c3afaec46&pf_rd_r=4040A5TJ68VZ161TFRXY&pd_rd_r=62e0fcde-faa1-46fa-9b8b-7651ec703d2e&pd_rd_wg=JTECI&pd_rd_i=B00LLGCL2C&psc=1&ref_=pd_bap_d_rp_c_2_3_sbo
                    #233357
                      Have these caps been tested for durability? Such as running them for a few hours and then comparing their uF reading to their original reading before installing them? Just asking because all caps are not created equally and even though they have the same uF rating, some can’t handle the torture given out by magneto systems.
                      #233361
                        nope.. not tested yet planning to try a few next summer .I know mr. Mohat hinges more on 850V caps based on all the testing he did. Obviously 850 is better than 630
                        Ceramics seem a better option but the yellow ones (with 850v) seem to do good when stuffed in the tall cans
                        These 630v ones can be fitted in the small cans . They test 100 % good on the capacitor test box (mdl#1) I built is winter .
                        So…. the 630 v ones ” seem ” well capable of tackling the 250-300v oscillations as shown on the scope shots in the Outboarder’s latest issued but I agree… real life testing is the way to go. .
                        I am just going on the basis that if a $2 full wave rectifier rated 50amps will do the job just as well of a $50 OEM 15 amp rectifier modern capacitor design and material may very well do just as good work as a 1950’s capacitor design for pennies instead of 10-15$ a piece.
                        if anyone has had bad experience with capacitor rebuilds using similar 600+volt caps … please let us know ๐Ÿ™‚
                        I don’t like rowing back to shore anyway !
