Home Forum Ask A Member Considering my first project
  • #2990
    vwtrey
      Hi everyone. My name is Trey. I have zero experience with outboards, but I’ve wanted a project for a long time. I came across this on Craigslist, and not sure if I should jump on it. The muffler is wrong, the grip is missing, but looks reasonably complete other than that. I’d appreciate a second opinion on it! Thanks
      http://santamaria.craigslist.org/bpo/5247415831.html
      #27169
      david-bartlett
        Trey,
        Welcome to the gang. While I cannot say what you should or shouldn’t buy, I will say follow your gut. If you want it, buy it. That motor is probably as good a starting point as any for a project. Quite simple, yet enough were made so parts should be out there. Patience is good to have also when looking for motors/parts. It is easy to spend more than you need in the heat of the "Chase".
        Again, welcome and happy tinkering.
        #27198
          The lawn mower muffler would indicate
          it’s had some hands on it during its life. Still the condition of the gas
          tank would make it worth taking a look at if its not to far away. Look
          for anything broken and the condition of the fasteners to see if its
          been wrenched on a lot. Should be able to get it for $50.00.
          However it works out, as this would be your first motor, your going to
          get some enjoyment from learning about it. What you will learn will
          be well worth $50.00 if you decide to buy it.
          #27204
          jerry
            VW…welcome to the world of greasy hands! The decision really depends on what you plan to do with the motor…run it? Display it? Sell it when done? That particular motor is reasonably priced and probably will never be a super valuable motor but it will be simple to put together…so if you’re planning to restore it to hang on a boat and get the thrill of accomplishing the restoration…"go fer it"
            #27206
            dougs-outboards
              I might suggest maybe for a starting point, maybe look for something a little more modern on CL like an Ev or JW series 3hp or 5.5, or something with the more common coils etc. It all depends on if you like the older models, or slightly newer versions, which I am partial to. Parts are abundant and the motor is easy to work on and learn. You should be able to pick one up for $50-$150.
              Whatever you do, have fun at it!
              Just my 1.5 cents worth…
              #27212
                The real old stuff like you are looking at are great for learning the history of outboard engineering. Once you learn that, the newer ones become much more simple (usually).
                #27217
                vwtrey
                  Thanks everyone for the input. I decided to go ahead and get it. However, I decided that a little late. It’s already sold. I’ll keep my eye out for another one. I’ve waited a few years, so what’s a little while longer? This one was only 10 minutes away, but something else will come up!
                  #31642
                  vwtrey
                    Well, I said it was sold. It popped up today on Craigslist for $50. I assume I could get it for $40. I’m considering giving him a call about it.
                    #31644
                      If you don’t get that one, try posting a want ad on the Free Classified section here. Since we are all outboarders here, I’m sure someone has an extra one they could part with.
                      #31647
                      1946zephyr
                        What kind of motor is it?
