Home Forum Ask A Member Convert double to single fuel line
  • #296315
    necks
      Going to convert fuel line on 1957 35hp Johnson to fuel pump with single line, for convenience. Question is can any fuel pump be used, or certain size only? I thought I remembered that there was a topic about it, How to convert double to single fuel line, that mentioned what style or model fuel pump  etc, that I read about, was either on AOMCI forum’s, or Antique Outboard Magazine. Been looking for this article for quite some time, so who better to ask but AOMCI. Thanks, Gene.
      #296318
        Topic: Evinrude Big Twin – Pressure Tank-Converted? Or not? – Antique Outboard Motor Club,Inc
        see this installation .. just drill a bypass cover and mount the pump over it with proper seal  so the crankcase pressure pulse will reach the rear of the pump. .    plug the now unused air supply going to the 2  line tank  connector and install a  single line side connector. .
        route the new fuel connector (engine side)  to the PUMP IN   and   PUMP OUT  goes to to the carb ! .
        #296321
          Your best bet is to update the top bypass cover to a newer style where the fuel pump would mount.  Then use a decent OEM fuel pump…
          #296323
          necks
            fleetwin, you mentioned it would be best to update the top bypass cover to a newer style where the
            fuel pump would mount. What would be the other bypass cover that would fit this 1957 35hp engine.
            Are the fuel pumps different on the fishing motors on up to the 35hp that I have big enough to work, like bigger fuel lines, more pressure easier to move fuel from tank. Thanks, Gene.
            #296325
