Home Forum Ask A Member Copper Tubbing
  • #8403
    green-thumbs
      I have run into a problem with sizes of copper tubing and fittings. It appears the required
      size is less than 1/4" O.D. I need about 6 inch length of a small diameter tubing plus two
      compression fitting rings. My junk box provided the correct fittings. The steel tubing
      they are on appears to be 13/64" O.D.
      Thanks
      Louis
      #65796
      Tom
        Any chance it’s 5 mm tubing?
        Tom
        #65798
        amuller
          Sure it’s not 3/16" tubing? That’s a common size.
          #65802
          RICHARD A. WHITE
            I have a roll of 3/16 tubing, I bought it at Napa…
            classicomctools@gmail.com
            #65804
            Goman
              If your looking for an odd size rigid copper tubing these folks may have it.
              http://www.onlinemetals.com/images/logo.pngtubing
              #65809
              green-thumbs
                Visited local industrial supplier during a slow period on an overcast rainy Friday afternoon.
                All but one item found. Clerk went out of his way to be helpful.
                Louis
