Home Forum Ask A Member Cork float weight
  • #249761
    GARY SMITH
      I have a DT38 Johnson carb with the cylindrical style cork float. Can anyone tell me what it should weigh ? Also where I might find a replacement if this one turns out to be no good.
      #249771
        I can’t say that I ever weighed a cork float. I bought
        a bag of corks off Ebay a few years ago, and
        just find one similar size. Some I’ve had to shorten, etc.,
        to use. Usually I seal them with super glue, and haven’t
        noticed any problems with their function yet.
        GARY SMITH
          I do have a bottle of old corks I could go through. I thought by knowing what it shoul weigh I could tell if this one was any good. I have instant glue here so I’ll give it a try .thanks.
          #249789
            porosity is more of an issue than weight I think. no tree is identical and cork density would vary anyway.
            Archimede law…. cork will displace it’s weight in fuel and float anyway !
            #249806
              You adjust the position of the cork, up or down,
              to a specified fuel level in the float bowl.
              In these the position is fixed by the slot that the
              clips goes in on the needle. It is not that critical on
              this motor. However in my experience it can be
              difficult to get the needle and seat to seal in
              these so you want to use as large a cork possible.
              Alignment of the hole in the center of the is cork
              is critical as you don’t want the needle dragging
              where it fits in the float bowl cover.
              #249870
              lloyd
                Weight is not critical but you want to use a cork with a minimal number of holes in it so that it will be easier to seal. If your original cork has lots of black areas that is a bad sign as it is mold that turns them black as it eats away the original cork. You can get a new cork at ACE hardware and cut it down to correct size. 1 3/16 ” diameter and 1″ tall for your motor. Lots of good info at : pochefamily.org/outboard. But note that the ad for my leather primer seals on that website is over 10 years old and the price is long out of date. New primer seals and instructions are $10.00 per set.
