Home Forum Ask A Member cork sealer
  • #6013
    td20
      What is a very good carb CORK SEALER ? I tried SIG Supercoat, model airplane, Fuel Proof, butyrate dope and it desolves in carb cleaner.
      #50143
        crazy glue ….
        #50144
          crazy glue ….seems to work for me … 2 coats
          #50154
          JOSEPH BRINCAT
            "devolves in carb cleaner" , ya’ I guess so. That’s really aggressive stuff meant to devolve hard deposits and other nasties. Your float need only resist modern gasoline. And then consider that most of our motors will only have gas in the tank and carb for a few hours before being drained and put away for another snooze.
            #50156
            gjonz
              Drill the hole in the float slightly oversized. Use thin viscosity super glue covering the entire float. Make sure the hole in the center gets coverage. Then clear 4th hole with a drill bit by hand if needed. Let dry and cure a few days.
              Greg
              #50159
              lawnlawn
                I used Damon Industries Red Kote fuel tank sealer. I brushed on 3 coats of sealer and it looks nice and red and dried quickly. Bought it from O’Reilly auto parts, but it is rather expensive($32.00). I can do another 5000 floats with this quart I purchased.
                #50160
                vintin
                  I’m doing real world testing on POR15 and will report results.
                  #50164
                  gjonz
                    For what it’s worth I soaked some floats covered in hot dope, epoxy, and super glue. The glue won out after 6 months floating I. 10% alcohol type gasoline.
                    Greg
                    #50176
                      btw…. super glue… crazy glue… I wrote to the CO. to ask about that very issue
                      they wrote back that NO the glue would not stand up to this type of use…
                      I use it anyway πŸ™‚
                      #50270
                      gjonz
                        So don’t tell them…or their attorneys! πŸ˜‰
