Home Forum Ask A Member Corn head grease delivery system
  • #4496
    bsplit
      What type of fitting/delivery system do you guys use to fill lower units with corn head grease?
      #38212
      mercuryman
        Put it in grease gun and take the grease fitting off and stick pipe in motor oil hole.
        #38214
        1946zephyr
          You can also take a grease nipple and put a rubber hose end on the threads of it, to form a good fit, when you pump the grease in.
          I have actually seen lower units with grease nipples on them, but that’s not eally a good idea. It’ll catch weeds and the water could make a mess of the spring/check ball assembly inside. Now, if you had a grease nipple that would thread in finger tight, that would work perfectly. Then unscrew it when you’re done and put the plug back in.
          #38238
            I found a screw on rubber nipple that fits the threads on the end of the grease gun tube.
            #38242
            david-bartlett
              Some Tractor Supply stores have "00" grease in a 1 quart squeeze bottle with a tip like a gear oil bottle. Squirts right in.
              #38315
              bsplit
                Thanks all
                Jim
                #38323
                rpsiii
                  Tractor Supply has a rubber grease gun tip that screws right on your grease gun.
                  It works perfectly and costs less than $5.00.
                  Probably available at NAPA, too.
                  Bob S
                  #38452
                  bsplit
                    Thanks, Bob…..I’ll check it out
