Home Forum Ask A Member Correct fuel / oil ratio for ELTO SERVICE TWIN Serial No. D27342 (1924 ?)
  • #9163
    Monte NZ
      International Member
      My Service Manual states 32 parts gas to 1 part oil, or 1/4 pint oil per gallon of gas for my motor. Is this OK as it seems very little oil and as I noticed that the manual for the 1926 Super Elto states 1/3rd of a pint of oil per gallon and as the motors are very similar,
      it has me a bit puzzled.
      The cost of the oil isn’t an issue, but I am very conscious of any oil going into our lake and wondered if the 1/4 pint per gallon is OK.
      Any help would be most appreciated.
      MonteNZ
      #70710
        why not use bio degradable oils… like xd-100… pricy but you won’t burn much
        #70715
          Sent you a PM.
          #70745
          Monte NZ
            Thanks very much Crosbyman and Tubs for your replies……..I never thought of using fully synthetic oil,although I use semi synthetic in my car.
            I have been using Valvoline 2 stroke outboard synthetic enhanced marine oil, NMMA TC-W3 and currently have over 20 litres stored in my workshop.I presume the word ‘enhanced’ means ‘semi’
            After receiving your replies I contacted the two major sources of oil here in NZ and was told that they only carried fully synthetic 2 Stroke for motorbikes (air cooled motors) and not for outboards(water cooled), so it looks like I will have to carry on using up my existing stock at this stage.
            In doing so, what ratio would you suggest……..a 1/4 pint per gallon (1 to 32) or 1/3 pint per gallon (1 to 24)?
            Interesting to note that there is no mention of biodegradable on my Valvoline containers.
            I watched your U tubes and was very surprised that you only use 3oz of oil per gallon !
            Thanks once again.
            MonteNZ
            #70748
              I have run all my oldies with 1 liter per 25 of gas. (jw qd fd) and suggested to some buyers of my oldies to do so
              not perfect .. not so bad
              a bit smoke is fine for bugs…
