Home Forum Ask A Member Correct plug wire routing for OMC mags
  • This topic has 10 replies, 7 voices, and was last updated 10 years ago by Don.
  • #3826
    opposedtwin
      Is this the correct routing of the spark plug wires? This is a 1958 18 hp Johnson.
      Scott
      [/url
      #33311
        Looks right to me…The only thing you might do is rotate the wire clamp on the head 90 degrees to port/left side of engine, you may want to route the wires below/behind the filter clamp as well. I know the wires seem like they get squished up between the vertical throttle rod and exhaust manifold, but that is the way they were routed during assembly. Adding a flexible sleeve (like that mesh stuff) covering both wires might help keep them from getting kinked/ pinched.
        #33332
        beerman57
          Those look too short to me. Shouldn’t they go down near the lower cowl?
          #33333
          wiscoboater
            How the heck did you get that motor so clean?
            #33336
              wannabe,
              Cannot answer for Scott, but what I do to a motor that is not getting full cosmetics:
              Tear off everything like mag plate, carb, etc…
              Soak in WD40
              Wipe off excess old grease etc…
              Blow out nooks/crannies with compressed air….
              Re wipe until nice and clean!
              Then start cleaning every parts, re greasing and re installing as you go.
              #33347
              opposedtwin
                Wish I could take credit but this is as purchased. It is in nice shape overall. I’m thinking it’s a low hour motor.
                #33353
                  What’s missing is the spring which hooks onto the wires to take the slack out of them. It should be below the sediment bowl.
                  #33356
                    quote Mumbles:
                    I was going to say that, but couldn’t find it in the parts book. Finally found it after considerable searching. Part #302827
                    #33359
                      quote FrankR:
                      quote Mumbles:
                      Where did you find it Frank??
                      #33378
                        Gale book. Item #18, attached to exhaust cover & shown way out of proportion.
                        free picture upload
