Home › Forum › Ask A Member › Crack in coil
- This topic has 10 replies, 8 voices, and was last updated 7 years, 10 months ago by
JACQUES.
May 21, 2018 at 3:25 am #9990
Has anybody ever tried to repair a crack in a coil casing. 1960 JW 3hp. Coils are readily available but this one has good spark and just a minor crack starting to appear in casing. Was wondering if any members have ever used a sealant with success.
Thanks much
Kevin
AKA SkegMay 21, 2018 at 12:23 pm #76471coils are 20$ … do you really like to row that much ?
https://www.ebay.ca/itm/Ignition-Coil-F … 2749.l2649get two while you are at it…. and get 3-4 feet of some nice brand new metallic core plug wire ! no carbon stuff
clean the points and you good for years and years of boating pleasure
May 21, 2018 at 12:39 pm #76472Yeah – I wouldn’t take a chance with coils beginning to crack.
May 21, 2018 at 12:50 pm #76474As stated, they will throw a spark, but WILL fail on the water. Always toss them.
May 21, 2018 at 4:33 pm #76489If you would like to experiment you could try using this.
You still have 1 cylinder to get you home. As to what is
taking place to the covering to cause it to crack – this
may be just the first of many cracks to come. If you
decided to continue using it and it doesn’t fail you
should check it at least yearly.
May 21, 2018 at 4:40 pm #76491It’s just going to keep on cracking and leave you stranded – Replace it!
DaveMay 21, 2018 at 7:29 pm #76502I’ve often thought of the time back in the day, when a customer brought in a 5hp Gale Sea King, complaining of hard starting an poor performance. A quick check revealed cracked coils, which I said had to be replaced. The guy was skeptical and doubted my diagnosis. Nevertheless, he consented when I told him it would run like new when I got done with it.
Fast forward a couple of weeks, and he was back. He sez "you lied. You told me it would run like new, and it doesn’t. It runs BETTER than new!"
May 21, 2018 at 9:11 pm #76503Super Corona Dope is good stuff, but I just use it on
old, hard to come by, coils, as it’s spendy, but a little
bottle goes a long way.https://www.circuitspecialists.com/4226-55ml.html
May 21, 2018 at 10:35 pm #76509quote Buccaneer:Super Corona Dope is good stuff, but I just use it on
bottle goes a long way.That is good stuff – Way back in a past life, I used to use it on high voltage flyback transformers in old TV sets. The problem is that insulation eventually breaks down between coil windings internally where you can’t do anything about it.
DaveMay 21, 2018 at 11:38 pm #76520 -
