Home Forum Ask A Member crankshaft balancing
  • #10511
    retro-outboard-guy
      Has anyone had any luck balancing a crankshaft on a 60’s big twin? It seems that these engines weren’t built with a decently balanced rotating assembly. I’m curious to see if anyone has had any experience with this? I have several crankshafts and they all seem to settle differently while laying horizontally on a balancing rail.
      #79331
        Yeah, I tried it. Removed shocking amount of metal. Motor vibrated as much or more than it did before. Conclusion: There is more to it than meets the eye.
        #79332
        retro-outboard-guy
          What amazes me is that the same crankshaft is used with the two ring 70’s 40hp engines and that piston and rod assembly is over two ounces heavier than the three ring assemblies of the earlier models. I guess they just weren’t worried about vibration.
          #79336
            Maybe the rotating assembly crank rods and pistons were balanced with the flywheel as one unit somehow.
            #79339
              That’s what I figure. The flywheel is part of the equation.
              #79343
              RICHARD A. WHITE
                Or the flywheel was actually the part that was modified to balance the entire assembly????
                classicomctools@gmail.com
                #79346
                  The pulse from ignition also needs to be considered.
                  It has a considerable effect on single horizontal firing
                  Motors. The more even the pulses around the rotation
                  of the crankshaft the less effect in has on vibration.
                  V-12’s & V-16 being the smoothest even in the 1920’s & 30’s
                  #79347
                  JOSEPH BRINCAT
                    A lot more complicated that meets the eye!! talking to an automotive engine designer ( we have several up here around Detroit) and you just begin to understand the complexity of engine "balance".
                    Joe
                    #79354
                      • This reply was modified 7 years, 2 months ago by Tubs.
                      • This reply was modified 4 years, 11 months ago by Tubs.
                      #79372
                      Pete
                        Well since you asked here are engine balance basics, never said it was simple:
                        https://motochassis.com/Articles/Engine … alance.pdf
                        How about this method, gotta watch the fingers?
                        https://www.bing.com/videos/search?q=ou … ORM=VRDGAR
