Home Forum Ask A Member Difference between 1957 35 hp Evinrudes 25930 & 25028
  • #5316
      I was just looking at my inventory list and pondering why I show two 1957
      35 hp Evinrudes, but one a Model 25930 and the other 25028.
      Do I have a "clerical" error, or did Evinrude have two different 35 hp
      models in 1957?
      I think the 25930 is a parts engine with no lower unit or hood, so
      I’m not sure I could readily tell the differences ….. and too dark
      and too tired out to go on a field trip.
      Thanks in advance for your insight!
      retiredoz
        What I can glean from my ref volume, the -028 was the basic Bigtwin with manual start, short , -930 was electric start, short shaft, and cost $180 more. No clues why, but I’d bet somebody knows.
        #44442
          The Old Outboard Book lists 25930 as "Electric Bigtwin", and the 1957 Lark as 25526…
          #44443
            Thanks guys! If it was me, I would have just used one number
            and put an "E" after it for the electric start version!
            I’m guessing that most parts will interchange then, if I
            need to swap a carb, internals, etc.
            Will have to see if the electric start motor and mount there.
            Thanks!
            1946zephyr
              About 99.9% of everything is interchangeable. Cosmetic stuff is basically the only diffference between all the models, mechanically. I have just a bit of that stuff from ’55 to ’59. Good vintage iron 😀
              The older 25’s do have smaller gears than the 30 and 35hp counterparts too.
              #44477
                Looked at the parts motor with no LU quick today. The electric starter
                is there, so if I get the complete one running I might have to think
                about adding electric start to it. Might have to borrow a bigger
                boat to try it out though…… the 15 hp on my little AlumaCraft
                was a wild enough ride!
