Home › Forum › Ask A Member › Dirty little Merc 4hp
- This topic has 2 replies, 2 voices, and was last updated 4 years, 2 months ago by
JACQUES.
January 3, 2022 at 5:03 pm #252277
started working on one of my winter projects… this long or ?? extra long 4hp had a bad recoil fixed up with you all’s guidance.
Down came the GC …. well surprise the front drain cavity was filled up to the top with hard packed sand !! . OMG The water drain hole never had a chance probably for the last 20 years !!
Impeller stiff but all there thankfully π
p.s. 4hp in the picture not mine… mine is longer
This topic was modified 4 years, 2 months ago by
JACQUES.
January 4, 2022 at 5:04 am #252321Welcome to the Dark Side. A lot of times that accumulated sand will expand and break out the side of the gear case. The original drain hole is about a sixteenth of an inch, which is ridiculously small. Virtually anything would plug it up. Your sand is only the tip of the Dark Side iceberg.
This reply was modified 4 years, 2 months ago by
billw.
January 4, 2022 at 8:34 am #252327Don’t worry…I was dark sided from age 18-55.. till I went ETEC (17 years) . these little Mercs are just low cost hobby investments to be resold for cost & parts only, to recoup my $$ .
Most go for about $150 cdn or less.
I am always amazed at how little some folks do not do “very” basic maintenance . A lot of motors run 30-50hrs / year & used for a trip or two in the wild
yet they can’t drop a gearcase to change an impeller and…clear sand away let alone a good coat or two of car wax.thankfully they supply us with hobby material to keep busy during snow storms and -25c temps π
btw… was looking on Amazon for chrome tape to touch up the cowl. A bit pricy but the local Dollar store had a nice sticky 5 roll tape kit with chrome finish tape in it for $2. π may not last long but looks pretty good. A shot of Mercury black and it will look like new π
lJoining AOMCI has priviledges π
