Home Forum Ask A Member Does a 6 volt lantern battery have enough amps to trip a 6 volt choke solenoid?
  • #10807
    outboardnut
      The 6 volt choke solenoid I have does not work with my 6 volt battery.
      I was wondering if the lantern battery had enough amps to activate it.
      I even hooked up three 6 volt batteries in parallel circuit
      I did a continuity test of the 6 volt choke solenoid and it was ok.
      #80922
        No idea on the batteries, but I used my old battery charger
        with the 6v charging option, when I tested my 6v choke.
        outboardnut
          My charger only does 12 volts
          #80924
            No , you need a motorcycle or garden tractor 6volt battery as a minimum. Or maybe a HO DC output model train transformer.
            #80937
            wbeaton
              A lantern battery should provide more than enough amps to actuate the 6V choke solenoid. However, if your 6V battery will turn the starter then your choke solenoid or it’s wiring is damaged.
              Wayne
              Upper Canada Chapter
              uccaomci.com
              #80944
                It will when new, but it won’t crank the motor. . . 😕
                #80974
                outbdnut2
                  It doesn’t do the battery any good – the choke solenoid is approx 6/10 ohm which draws 10 amps at 6 volts. Spiking a lantern battery like that may cause it to develop leaks, and, like Garry said, it won’t last long. An alkaline lantern battery is a mess of AA cells wired in a series/parallel configuration. A carbon-zinc lantern battery may not work at all.
