Home Forum Ask A Member Does a JW-12 Johnson 3 hp have a tell tale?
  • #2146
    boatman
      Hi guys,
      Does a ’56 3 hp Johnson have a tell tale, or does the pumped water exit under water with the exhaust? If so, should the water come out as soon as motor is started.
      Thanks,
      Paul
      #21167
        No "pee hole", you should see water come out in the above the water "exhaust relief"
        #21169
        boatman
          Phil,
          Thanks.
          Paul
          #21170
            If you look at the front of the midsection, right below the transom mounts, you will see a small square piece with a screw in the middle of it. This is the exhaust relief and the water will come out here. Don’t expect a strong stream as it just dribbles or sprays out and can be hard to see. It should start coming out shortly after startup.
