Home Forum Ask A Member Does anyone rebuild late 40’s Johnson 5hp in MI?
  • #253317
    worldrallyoffrd
      Hello,
      I tried my hand at rebuilding my great-grandfathers Johnson 5hp outboard (TD15) but, it needs more help than I can provide right now. Is there anyone in the midwest that rebuilds these engines I could reach out to? Especially if they’re around Southwest Michigan.
      As always thanks for the time this place is an awesome resource.
      Jordan
      #253318
        If someone here doesn’t reply to you directly, you can look at the links below.
        There’s two active AOMCI chapters in MI, and there’s one listed in Indiana.
        Hopefully they have contact information.
        http://wolverinechapter.com/
        https://www.liquidassetsonline.org/
        https://www.michianaoutboardboating.org/
        Also, there’s lots of people here that can walk you through your particular
        problems if you want to try to fix it yourself.
          exactly was “rebuilding” is intended ….total  as in  pistons, cyl rebore, repaint    etc… or   carb/ignition/gearcase  stuff ??
