Home Forum Ask A Member Double hose conversion
  • #225410
    GLEN DEUTSCH
      I am doing a double hose/single hose conversion. I know that you don’t need to go into the reed plate for some of the Evinrude/Johnsons but I cant remember after what year. Want to keep it simple.
      #225412
        what model engine is it ??? if 5.5 you may as well use the air nipple to feed your pump for other models 7.5 10hp …… I think the pump on a plate is the best way to go
        presently working on a 10hp myself
        you can also do a B &S pump on a frame attached to the back cross-bar if your engine has one… but you will need a vacum pulse either from the air pressure nipple or a drilled cover plate with the air pressure nipple block out with a piece of short fule line anda short bolts tuck in it
        https://www.youtube.com/watch?v=ojOMbwvH55I
        https://www.youtube.com/watch?v=FtG4M7ye1N8
        • This reply was modified 5 years, 2 months ago by JACQUES.
        #225423
        GLEN DEUTSCH
          Thanks crosbyman. Very helpfull
          #225451
            if you do “pump on a plate” make certain you do not obstruct the cowl or any mechanical operation . Some square pumps have a thicker base and extent out a bit more
            Drill the side cover plate 1/4inch just behind and in-line the square pump to get a crankcase pulse.
            Off-set the pump with one bolt in the cover plate region and one bolt outside the cover . use the pump base gasket as a guide to properly position the pump and drill the 3 holes to mount the pump plate.
            plate is 1/16 inch aluminum. the engine cover plate should be made 100% dead flat by doing figure 8s over 120 grit paper over a large glass or tile surface. it will be dead plat when all the paint is rubbed off and checked with a square edge for flatness.
