Home Forum Ask A Member Dumb Questions? Maybe
  • #8877
    loggerhead
      I’m pretty new here but had a rather long post that took me awhile to compose. I hit the “save draft” button but can’t find out where the message went? I hope I didn’t “time out” and the message was lost.
      #68871
      wagemaker
        Try clicking on your name (upper right), then click on "user control panel", then click manage drafts" on the far left.
        Hope that helps.
        I usually compose stuff in MS Word then copy & paste that way I have a copy if S… happens.
        #68872
          Nope, not dumb at all. In fact, that’s a good question!
          If you go back to where you saved your draft, make sure to click on the ‘Full Editor And Preview’ button at the bottom to bring up another box which will have a ‘Load Draft’ button at the bottom. Click on it and your saved draft will appear again.
          loggerhead
            Thank you! Thank you! Thank you! I just knew my message had gone to another space and time! (See post: Corsair “Special Nut”)Great idea to compose in MS Word and transfer over. Thanks again!
            #68890
              Here is another way
              #68896
                [Load Draft] never came up when I tried it I had to write the whole thing over again. . . 🙄
