Home Forum Ask A Member Early 4-60 racing outboard ignition system.
  • #302663
    Carl Wassersleben
      Looking for info on early Evinrude? 4-60 ignition systems. I’ve rebuilt a couple of Elto systems. Have questions about the early 4-60 systems. Coil tube looks about the same. Who can tell me more about it. Points, trigger. Just have the coil assembly at the moment. Another project to contemplate.
      #302665
      RICHARD A. WHITE
        If interested in building a new coil, I can help..No help on the points, but, I believe that tube is like just under 12 inches long????…. I can 3d print a tube and inserts to hold a pair of military surplus dual output coils so you can run it and not potentially damage the original coil..
        classicomctools@gmail.com
        #302668
        Carl Wassersleben
          Great! With the Elto. I float the internals out, I replace with those old military generator coils and condensers. New Packard spark plug wires and encapsulate with wax. Works like a charm.
          do those 4-60 coil assemblies have the condenser in with the coils or are they under the flywheel?
