Home Forum Ask A Member Early ELto Ace Parts
  • #2445
    skeg
      Hello fellow members, I am looking for parts for an Elto Ace. I have an earlier model from 1936 serial number 4145-0883. This is the model with the integral mag advance lever built into the mag plate vs being screwed on. I am looking for the mag plate with handle intact as well as a complete fuel line assembly including the connection to the tank and the adapter to the carb. Would consider purchasing parts motor if required. Tried Doug Penn and he does not have one. Also tried a few other known sources and no luck so I thought I would give this a try as these are last two pieces I need to complete this surgery.
      Much appreciated.
      Kevin McGrath
      AKA SKeg
      651-271-2698
      mcgrath1281@gmail.com
      #23212
        My 4145 Ace also has the magneto lever knocked off. The decals on the sides of the tank are better than average however. That was an adaptation of the 1934/35 Sportsman and required a special magneto base because of the high carburetor mounting. I am going to try to have it welded up, if I can find a good picture of an origenal.
