Home Forum Ask A Member Early QD Carb Float
  • #2517
      Has anyone successfully made one? I bought some cork material off ebay to attempt this myself. I bought stoppers much larger than I needed, so I could cut them down.
      I ended up with a bench full of cork debris when I was done ;)<
      My hole saws just tore the cork up, couldn’t get a clean cut through it. I suspect it was due to the quality of the cork, seemed `loose` and airy.
      My original is shot. It is so swollen it barely fits in the float bowl, and sticks on the way up and down, flooding the motor.
      I would think carving one out of a new style float would go better, but have never seen one as thick as I would need to do this.
      Any thoughts, or know where to get one?
      #23744
        I wonder how hard it would be to reverse engineer the material used on the black floats, then make a mould and make our own floats?
        #23795
        dmbono
          it’s easier to sand the cork. I have a1" bench machine and I just spin the cork against the belt.
          #23798
          1946zephyr
            What year QD? They likely are still available through Sea-way marine, if not at your local OMC dealers. Also try Engine Blade and Prop. Ganoteck. I understand is another source.
            As far as making and selling your own? Heck yes. Outboard enthusiasts greatly appreciate your help.
            My good friend Frank Robb makes excellent tools
            #23801
              A member is sending me a NOS one!
              Zeph, I tried all the usual sources, none had one. This is for the early QD10, the fat float.
              #23803
                Since problem is solved, I guess this is moot. But if I had to make one, I think I would explore the possibility of using a new Nitrophyl float for the 18-up motors of later years and see if it could be cut and shaped to fit the original brass hinge. OR, even the Nitrophyl one that replaces the cork float in newer QD’s etc. Just thinking out loud.
                #23810
                  I had thought of that Frank….I could not find any in my stash with the correct amount of width. I found one with too large an OD that I could sand down, but couldn’t get it flush with the carb casting as it was not wide enough…..wasn’t sure how to overcome that with the original hinge.
                  #23811
                  beerman57
                    There is a problem with these boards, if I write a response but someone posts a response while I’m writing, my response disappears!
                    #23814
                      If that happens, it should give you a chance to edit your response, and show what the other poster that posted first wrote, then you hit send again.
                      #23822
                      1946zephyr
                        quote Chris_P:
                        How about trimming one down from a 5.5/7/5?
