Home › Forum › Ask A Member › Elto Pal fuel line
- This topic has 15 replies, 8 voices, and was last updated 8 years, 10 months ago by
mike-stroz.
May 10, 2017 at 9:33 pm #6980
I just picked up another Pal today, and it looks like it’ll run as is- good compression and spark, clean carb. The one problem it has is a kinked fuel line. Anyone know where I can get a new one or have one made? I can’t make it myself since I don’t have the tools.
May 12, 2017 at 2:56 pm #57598May 14, 2017 at 7:14 pm #57712It’s the one in the bottom picture.
May 15, 2017 at 2:04 am #57725May 16, 2017 at 12:59 pm #57798Great write up Tubs.
Mike as Tubs said "you can do it" . It’s not that hard. Give it a try, the materials are all relatively inexpensive as, so it won’t cost a fortune if you screw up your first time.May 16, 2017 at 11:34 pm #57821I’ll give it a shot, but I think I’m going to have to order some pieces online. None of my local shops carry any of it
May 17, 2017 at 3:34 am #57834quote Mike Stroz:I’ll give it a shot, but I think I’m going to have to order some pieces online. None of my local shops carry any of itLowes, Home Depot, Menards. All will have the fitting but probably not the copper line.
This is small town hardware store or farm store stuff.
Common size for Ice maker water line.A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
May 17, 2017 at 7:19 pm #57871Anonymous
Actually I bought a coil of copper tubing at menards. Enough to make a few dozen fuel lines. In the plumbing section.
May 17, 2017 at 9:49 pm #57881Ferrule is correct when used on tubing, referred to as grommets or eyelets when used to line holes. It uses quarter inch copper tubing. Ferrule is a adaptation of two Latin words meaning a small iron bracelet. . . 😉
May 17, 2017 at 10:44 pm #57885quote kirkp:Actually I bought a coil of copper tubing at menards. Enough to make a few dozen fuel lines. In the plumbing section.Yep, Home Depot has it, too. They sell 1/4" tubing in the plumbing department with all of the other piping. I think I got ferrules off of eBay for a good deal. You can also buy spring-type bending tools that will prevent kinks:
http://www.homedepot.com/p/HDX-Tube-Ben … ing+spring
