Home › Forum › Ask A Member › Elto PAL ignition coil
- This topic has 6 replies, 4 voices, and was last updated 1 year, 7 months ago by
Buccaneer.
March 19, 2024 at 1:37 pm #286040
Elto Pal model 4266 – I recall that the topic of coil substitution has been addressed here previously, but to no way could I find that thread…. help! Perhaps it was using the surplus military coil? but no point in re-inventing the wheel when brighter minds have already solved the problem.
March 19, 2024 at 10:47 pm #286047
I’ve had a bunch of Pals, Scouts, and Rangers
and more that half of then didn’t produce a
spark. But it was always the points that needed
to be taken apart and cleaned. I’ve never had a
bad coil. However if your coil is bad,
substituting the surplus military coil should
be relatively easy.
March 19, 2024 at 11:24 pm #286049Thanks Tubs, I will go through the points as suggested. maybe there is hope, although the coil shows open with the VOM I do get spark on the Mertronic… hope springs eternal
March 20, 2024 at 11:51 am #286055
Yours would be bad then.
I don’t know what the voltage reading is
when that coil is suppose to fire.
If your cranking up the Merc- O- Tronic enough
spark may be jump the gap.
.A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
March 21, 2024 at 10:12 pm #286117Where might one find a military surplus coil? I have a Johnson HD 15 with an open secondary coil. Mine looks identical to the one in the right side pic.
Ken
March 21, 2024 at 10:18 pm #286118
Club Member Big Rich has them- Link – https://www.ebay.com/itm/134873327898?itmmeta=01HSJ016C9ZFG96CHX20GAR60C&hash=item1f6713a91a:g:Ve0AAOSwe8VkVUyZ
TubsA "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
March 21, 2024 at 10:20 pm #286119 -
