Home Forum Ask A Member ELTO RUDDER TWIN 1922 ASSEMBLY PROBLEM
  • #240836
    Bill Roth
      I dissembled the lower unit from the powerhead on a Elto RT that was free and the flywheel turn as is it should. I took it apart for polishing. The lower unit and powerhead turn easily before. I’ve now have reassembled it twice and the first time it was totally stuck. Second time, right now, I assembled it only using 2 of the 4 bolts to attach the lower unit to the powerhead without the prop on. On the second assembly the flywheel it is quite stiff. Shaft and head went together fairly easy so I feel its aligned right. Any idea what I am missing?
      I have done this before on an earlier 1922 without any problem.
      Bill in MN @: anbroth1544@gmail.com
      #240846
      BROOK E. NEWCOMB
        Did you replace the crankcase base gasket with the correct thickness? If it is to thin or no gasket at all it could cause the condition you are describing
        once you tighten it down. Your crankshaft end play will be governed by your base gasket thickness. Do you have any end play?
        Respectfully,
        Brook
        #240944
        Bill Roth
          Brook thank you for you suggestion. I may have a to thin a gasket material. I will loosen the bolts on the bench and back the lower unit down to see if that helps.! I will let you know.
          #240952
          Bill Roth
            I backed the lower unit 1/4″ off from the head without any luck. Still locked up. End play, could you elaborate what you mean, on the drive shaft in the lower unit?
            #240965
            Bill Roth
              I now back the lower unit away and the power head 3/4″ away from each other and both moved freely. ????? Each time I kept both 2 pieces as close to level a I possible..
              • This reply was modified 4 years, 9 months ago by Bill Roth.
              #240988
                • This reply was modified 4 years, 9 months ago by Tubs.
                • This reply was modified 4 years, 8 months ago by Tubs.
                #240992
                BROOK E. NEWCOMB
                  Bill,
                  Nice chatting with you tonight, let us know how you make out.
                  Respectfully,
                  Brook
